swapping transmissions
Old 04-25-2006, 08:28 AM
redhanyo's Avatar
Default swapping transmissions
i have a b16a3 motor w/stock tranny. If i buy either jdm/usdm itr or jdm ctr tranny, do i just slap it on, or do i have to get some extra stuff to make it compatable? Dont know about transmission swaps, so any info would help.
Old 04-25-2006, 08:29 AM
RaYnE's Avatar
just curious why you would be doing this swap? the b16 tranny is a good tranny.
Old 04-25-2006, 10:26 AM
redhanyo's Avatar
Default Re: (RaYnE)
i believe the synchros are going out on second and fifth. and i think i have to change the clutch too. maybe start autox and track this summer, so... might as well buy a new tranny with lsd. Im trying to debate if its cheaper to buy, or replace synchros and install lsd in stock tranny.
Old 04-25-2006, 11:10 AM
black_EM1's Avatar
Default Re: swapping transmissions (redhanyo)
If that's the case, I'd just get a CTR tranny. Same gear ratios, but with LSD. Unless you can rebuild your tranny yourself. If you can, then you should just buy the parts, and have a rebuilt one on the cheap. Be warned, however, good LSD's are not cheap
Old 04-25-2006, 12:36 PM
redhanyo's Avatar
Default Re: swapping transmissions (black_EM1)
i need to learn, so if a new tranny doesnt have same gear ratio as stock, then what do i do to make it work.
how about i ask it like this. Can i buy an itr tranny and install it on my b16, or do i need to get extra stuff to make it work?
Old 04-25-2006, 12:40 PM
sol2hatch's Avatar
should be a straight swap. thats how it is with dseries engines at least. I am sure its the same with the b series. The different gear ratio doesnt matter when you swap, it will still work, just the car will drive differently.
Old 04-25-2006, 12:46 PM
redhanyo's Avatar
Default Re: swapping transmissions (sol2hatch)
differently how? as in harder to drive? funky shifts?
Old 04-25-2006, 01:00 PM
HXvtec's Avatar
thank God this isnt a will a 95 civic tranny fit on a 98. to answer your question yes they will fit. they're all b series.
Old 04-25-2006, 01:10 PM
Go Tigers!
Bense's Avatar
Default Re: swapping transmissions (HXvtec)
Learning route?
buy a cheap ls tranny and use it while you rebuild your b16 transmission, while building it, order a 4.785 final drive and install it with a used ITR lsd. gear-speed.com has tranny rebuild kits.
Fun with ball bearings!
then sell the LS tranny.
Or you could just save yourself all the hastle and just get a ctr tranny. My fully rebuilt d-series transmission is going to cost me more than a jdm k20a dc5 ITR lsd 6-speed trans. But my d-series trans will be FULLY BUILT YEAHHHHHHH
Old 04-25-2006, 03:01 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redhanyo &raquo;</TD></TR><TR><TD CLASS="quote">
i have a b16a3 motor w/stock tranny. If i buy either jdm/usdm itr or jdm ctr tranny, do i just slap it on, or do i have to get some extra stuff to make it compatable? Dont know about transmission swaps, so any info would help.</TD></TR></TABLE>
ITR tranny &gt; CTR tranny &gt; B16 tranny period. For any instance of racing.
Have fun with autocross
Old 04-26-2006, 03:25 AM
black_EM1's Avatar
Default Re: swapping transmissions (fast88std)
True
Old 04-26-2006, 04:20 AM
Sleepy_Red_hatch's Avatar
lol whats so special with the CTR tranny? its the EXACT same as the b16 tranny + a lsd, you could get a LSD b16 tranny probably for cheaper then a CTR just because its not "CTR" B16B motors/trannies are expencive due to their rarity.
Old 04-26-2006, 12:55 PM
redhanyo's Avatar
Default Re: swapping transmissions (Sleepy_Red_hatch)
so gearing is the same for ctr and usdm stock b16?
dafreeeze
Transmission & Drivetrain
10-22-2012 06:08 AM
vtec25
14
03-14-2006 08:26 PM
spcrxracer
07-07-2004 04:37 AM
drumsy
02-27-2002 09:12 AM
Quick Reply: swapping transmissions
