b16a high idle
b16a high idle after swap
I just finished swaping out my b16a2 block for a b16a and now the idle is at 1.5k. was running w/ stock ecu then switched to a p28 chipped since im not using the crank angle sensor. both ecu's(p28/chip-stock) idle at 1.5k. anyone know why its idling at 1.5k? thanks
Re: (Jay_Sensing)
thanks for the input I good found out it was a speed sensor wire. now im having trouble when releasing the clutch after startup it starts to make this loud noise coming from the trans most likely a bad lsd intall. happen to anyone before?
