lsvtec ?s inut needed
ok,..i have a rebuilt ls block with rods,..with the b16 pistons in it,..i have b16 head w/port matched intake & p/p pr3 IM...im running a ls tranny with the itr lsd,so it hooks up,....& i can also take the gears weigh out there,..i have a crome tuned dual stage ecu set @ 5000...with the vtec @ 4500,...my rev limiter is 85,....now i know im goin to need a valvetrain upgrade what would be a good brand to install the zex stage 2 cams,..but what should i set the rev limiter too,...& how much power would be a good estimate from the wat its set right now,..& with the cams
Re: lsvtec ?s inut needed (egsr6)
go with blox springs and retainers and the type b cams. made 217 whp for me on my LS vtec. i'd ditch the LS tranny and go with a b16 tranny. and after all that you should go get it tuned. you willl gain the most power outta the tune
Re: (JdmLub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmLub »</TD></TR><TR><TD CLASS="quote">u can rev the gears higher in the b16 tranny </TD></TR></TABLE>
thats not exactly true
the b16 tranny has shorter gears, i believe that 1st gear may be the same however
anyways, it allows you to accelerate faster for all intensive purposes
Re: lsvtec ?s inut needed (outkastdc4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by outkastdc4 »</TD></TR><TR><TD CLASS="quote">if you keep your ls tranny and you rev higher you will do better than if you had a b16 tranny....you will cover more speeds</TD></TR></TABLE>
what does rpm's have to do with each tranny? they both will handle any redline your engine will most likely see
as far as covering more speeds, thats a little misleading to say that
you will lose some top end (your top speed will be a little lower) but you will accelerate faster through the gears
its the same concept as regearing a rearend in a rwd car
ex. if you regear from a 3.73 rearend to a 4.10, your rpms will be higher at say 90 mph, however you will accelerate faster to that speed
but thats just explaining it simply, it has a lot to do with what the car will be used for and what rpms you will be using most of the time and so on
Re: (MajorPayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MajorPayne »</TD></TR><TR><TD CLASS="quote"> i believe that 1st gear may be the same however</TD></TR></TABLE>
julio_bOostamante
24
01-05-2006 04:53 PM
