Crank sensor??
Crank sensor??
i have a 99 si motor that im putting in my 97 civic..im going to run i obd1 ecu..my question if i leave my crank sensor unplug will my car still turn on and run????
Re: Crank sensor?? (blowbyu24)
my stock harness has a 3 plug for the crank sensor and the si motor has 2 plug.. what do i need to do bout that???
OBD1 ecus dont read the CKF sensor next to the crank gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blowbyu24 »</TD></TR><TR><TD CLASS="quote">my stock harness has a 3 plug for the crank sensor and the si motor has 2 plug.. what do i need to do bout that???</TD></TR></TABLE>
Let it hang?
Let it hang?
the plug on the crank is a crank fuckuation sensor and the wway i understood it it was only there to help with misfires so even with a obd2 car you dont realy need it , on obd1 and obd2 the crank angle sensor is in the dizzy
aznlaoboi315
09-09-2007 02:59 PM
