foglights Q.....again
is there a way to wire up your foglight for it to turn without the parking light needing to b on? because the common way to wire the foglight is for it to turn on only when the paking light is on....right?
cansome1 direct me or give me a link to where i can find good write up on diy foglight install
thanx
thanx
did you hook up your foglights yourself? if so, the plug that you plugged into the cabin fuse box...disconnect it and plug it all the way to the right... here's a ghetto example...ill try to find that schematic of it for you.
[ ][ ][ ][ ][ x ]
[ ][ ][ ][ ][ x ]
HT White Ops
Re: (13BT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13BT »</TD></TR><TR><TD CLASS="quote">did you hook up your foglights yourself? if so, the plug that you plugged into the cabin fuse box...disconnect it and plug it all the way to the right... here's a ghetto example...ill try to find that schematic of it for you.
[ ][ ][ ][ ][ x ]</TD></TR></TABLE>
All the way right is ignition dependent, and will only come on if the car is running.
HT White Ops
Re: (13BT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13BT »</TD></TR><TR><TD CLASS="quote">does it? on mine it can be turned on in ACC.
well here is the picture
Yes, I realize that. But sitting with your key on ACC just to have your foglights on is not common. I say running for all intensive purposes. For a 5th gen, A+B will be hot all the time. In a 6th gen, A will be hot all the time.
This is the thread I used to help me install my fogs, hopefully it helps you out too. Good luck!
https://honda-tech.com/zerothread?id=1352749
thanks fella...no i did not installmyfogs yet because i wanted to get a few thing cleared up.
http://jdmlyfestyle.com/images/DSC03465.jpg
so...did this guy had it set up for it to turn on only when he had his parking lights on???
because thats the fourth one he has it in...and if he'd put it in the last one...he could of turn it on the acc..correct me if im wrong
HT White Ops
Re: (spintboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spintboy »</TD></TR><TR><TD CLASS="quote">thanks fella...no i did not installmyfogs yet because i wanted to get a few thing cleared up.
because thats the fourth one he has it in...and if he'd put it in the last one...he could of turn it on the acc..correct me if im wrong</TD></TR></TABLE>
If you have it set up with the parking lights, you should be able to turn it on without the keys in the ignition. If you put it in slot 1, it'll be able to turn on, no matter what.
pumpkyn
06-01-2006 11:54 PM
boredracer408
02-02-2004 05:17 AM
