whining noise on clutch release?
OK so I went with a freind to go look at a car today,
was a 96 dx hatch, all stock.
everything looked good, except it had this gnarly noise when you would let off
the clutch pedal in first and sometimes second.
basically right where the clutch grabs it would sound like a loud metallic scraping.
high pitched, like metal on metal sort of thing.
clutch still worked fine, car drove fine and everything, just that sound was the problem.
So we passed on the car,
but i'm still really curious as to what you guys think that was??
clutch problem, or tranny problem, or what?
thanks!
thanks!
HT White Ops
Re: whining noise on clutch release? (JdmEj1!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEj1! »</TD></TR><TR><TD CLASS="quote">could also be a throwout bearing, which is also easy to fix yourself if u can take a tranny apart</TD></TR></TABLE>
No, it really couldn't be, not if you actually read his post.
Noise when clutch is released: ISB
Noise when clutch is depressed: TOB
Re: whining noise on clutch release? (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Input shaft bearing. Very common problem, very easy fix if you can pull a tranny apart.</TD></TR></TABLE>
That's what I would have said.
Nah, doesn't sound like it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmEj1! »</TD></TR><TR><TD CLASS="quote">well when my throw out bearing was going out, mine did that ****.</TD></TR></TABLE>
It was squealing/scraping when you were <u>pulling out the clutch</u>?
Re: whining noise on clutch release? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
It was squealing/scraping when you were <u>pulling out the clutch</u>?</TD></TR></TABLE>
ya man... i replaced it and everything was a ok... I heard from a friend of mine that was wierd, usually it'll just make your gears grind and ****. BUT it worked for me...
i would think that if you have a bad throwout bearing, you would hear noise at around 2,000 rpm regardless of what gear you are in. someone correct me if im wrong.
prjctwhteg
10-29-2007 03:34 PM
