Will a '93 D16Z6 speedo sensor work with a 2000 Si (Y21) transmission?
As stated in the title, Will a '93 D16Z6 speedo sensor work with a 2000 Si (Y21) transmission???
Re: Will a '93 D16Z6 speedo sensor work with a 2000 Si (Y21) transmission? (jdm_vtec)
first off you would have to change the gear from one to the other..
we got the d-series sensor with the b series gear into b series motor
its works sometime and sometimes it dont.. might be the car.. but you sould try it
when its working it is correct
Re: Will a '93 D16Z6 speedo sensor work with a 2000 Si (gezzuzz)
sounds like swapping the gear might actually work.. did the sensor work 100% in the D-series setup or do you even know?
Morning Call
05-19-2005 02:34 PM
