Motor Mount
Motor Mount
Hi
Can someone tell me how hard it is to change the lower driver side motor mount on a 1998 Civic EX. Mine is broken and the dealer want $190.00 to change it out .
Any help would be appreciated.
Thanks
Thanks
Re: Motor Mount (Rhood)
not hard to change the mount the camgears....if you looking for a stock mount, hit up a junkyard and make sure you put your motor on a jack before removing the mount..
if you taking about the mount that goes by the AC Condensor, no need to jack the motor..
are u talking about the lower one that is on the a/c bracket if its that one its only two bolt on the frame and one big screw for the bracket, just jack the car up and take the wheel off and youll see how simple it is..
Re: (Rhood)
don;t buy a new mount.. get a insert.. those mount break easy the new one will break in a few weeks
http://cgi.ebay.com/ebaymotors...58045
Re: (hatch-E-vanish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish »</TD></TR><TR><TD CLASS="quote">are u talking about the lower one that is on the a/c bracket if its that one its only two bolt on the frame and one big screw for the bracket, just jack the car up and take the wheel off and youll see how simple it is..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">those mount break easy the new one will break in a few weeks
thats not true. it usually rotts out.
If you do NOT have AC do you need to keep the mount that goes there? My bushing is totally shredded and I'll leave it off if I don't need it... I plan to upgrade the other mounts.
imadigitalgod
05-29-2010 11:32 PM
