brand new battery is dieing
Old 01-12-2007, 11:11 AM
smokecdxx's Avatar
Default brand new battery is dieing
so i just replaced my battery and alternator 2 months ago
and now my battery is dieing like its not getting charged by the alternator
so my question is do any of you have any suggestions on why this might be happening........
thanks
Old 01-12-2007, 11:13 AM
fmrprojects's Avatar
Default Re: brand new battery is dieing (smokecdxx)
you got a short somewhere that is drining your battery
Old 01-12-2007, 11:20 AM
smokecdxx's Avatar
Default Re: brand new battery is dieing (fmrprojects)
would that cause it to die when im driving though??
cause the other day i was driving it and all my lights started dimming out...bad like i had to turn my brights on and i barly could see anything.....
then i came up to a stop sign and i slammed on the gas after stopping and when i shifted into 2nd real hard all my lights came back on...
so yeah.
would that still be a short?
Old 01-12-2007, 11:23 AM
AdamB18C1EK's Avatar
get a multimeter and check to see if your charging system is actually charging the battery. see how many volts its getting when the car is at idle...i think its supposed to be around 14...mine was...but if it isnt charging its your alternator, if it is charging your battery or terminals are junk. p.s. if your batter isnt charging check all the connections at the battery, starter, and alternator, then check to see if the fuse for the alternator sensor is blown.
Old 01-12-2007, 11:26 AM
HT White Ops
Eran's Avatar
Sounds like you have parasitic drain somewhere in the system.
Any recent audio installations? Grounding kits? Foglights?
Old 01-12-2007, 11:33 AM
Default Re: (Eran)
my homie had the same problem and it was his alarm drining his battery. had a short. he would signal and his car would die
Old 01-12-2007, 11:40 AM
Unceasing Measure
Archidictus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokecdxx &raquo;</TD></TR><TR><TD CLASS="quote">then i came up to a stop sign and i slammed on the gas after stopping and when i shifted into 2nd real hard all my lights came back on...</TD></TR></TABLE>
This little fragment of information suggests to me that you have a loose connection or ground somewhere. There's no other logical explanation for that kind of charging system behavior.
Old 01-12-2007, 11:46 AM
smokecdxx's Avatar
Default Re: brand new battery is dieing (AdamB18C1EK)
where is that sensor fuse at....cause i have looked though my fuse cover lokking for anything that would deall with the alternator.......but havent found anything at all....so maybe im just having a moron moment and im not seeing what you are taling about or im not looking in the right place.
Old 01-12-2007, 12:37 PM
boostmywankle's Avatar
my first step would to see how much parasitic draw there is. check current flow, and 50mA is a good refernce number.
Old 01-12-2007, 01:35 PM
bart2546's Avatar
Default Re: brand new battery is dieing (boostmywankle)
Deffinitely do a parasitic draw test. I mean a basic (and NOT efficient way) to check is to see if anything still turns on when the car is off. Sometimes it's the radio or something stupid like a defroster too. But it still sounds like an alternator problem. I know you just put a new one on but it still could be bad. Was it a rebuild? Also check to make sure your ground and power connections to and from the alternator are secure and tight.
Old 01-13-2007, 04:38 PM
smokecdxx's Avatar
Default Re: brand new battery is dieing (bart2546)
THANKS EVERY ONE
I JUST FOUND OUT THAT MY 2 MONTH OLD ALTERNATOR WAS BAD
BUT THANKS FOR ALL YOUR HELP
Old 01-13-2007, 04:40 PM
HT White Ops
Eran's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokecdxx &raquo;</TD></TR><TR><TD CLASS="quote">THANKS EVERY ONE
BUT THANKS FOR ALL YOUR HELP</TD></TR></TABLE>
Lemmie guess ... not OEM?
Old 01-14-2007, 12:06 AM
smokecdxx's Avatar
Default Re: brand new battery is dieing (Eran)
you are very correct my friend
not oem indeed.....
i got a rebuilt
bad move
samdawgsol
04-03-2005 12:02 AM
crimsoncrx
11-05-2004 03:48 PM
GroundZer0 336
03-06-2004 05:55 PM
imnotswapped
02-17-2004 10:03 AM
Quick Reply: brand new battery is dieing
