Civic cylinder 4 randomly misfire??
Re: Civic cylinder 4 randomly misfire?? (team 15)
90% of the time its spark plugs
make sure to use NGK
also it might be the wires.
do a tune up..
spark plugs, sp wires, disubtor cap and rotor..
do a tune up..
Re: Civic cylinder 4 randomly misfire?? (gezzuzz)
I agree completly with previous comments but, it sometimes means you have no/low compression in that cylinder too. Might be time for a compression check. This is a chronic problem in S2000's when they've been run low on oil and the bore gets scored up.
Re: Civic cylinder 4 randomly misfire?? (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan »</TD></TR><TR><TD CLASS="quote">I agree completly with previous comments but, it sometimes means you have no/low compression in that cylinder too. Might be time for a compression check. This is a chronic problem in S2000's when they've been run low on oil and the bore gets scored up. </TD></TR></TABLE>
its could be a rat made a next on top of the fuel tank. and rat **** fell into the tank and cloged injector #4.. but we sould test the easiest and most common things first..
Re: Civic cylinder 4 randomly misfire?? (EL Vap133)
deff do the tune up i had random misfires on my civic. once i did a tune up purred like a kitten. hondas a very picky about there spark
stuckinkaos
19
09-03-2013 09:52 AM
LSVTEC 91 Civic
25
07-12-2004 01:49 AM
