Real Quick Question
Real Quick Question
Just wondering if a D16Y8 (I believe that is the one out of the 99 civic ex) head will fit on my D15B7 block. Just wondering if I will have nay complications with the OBD-II head on my OBD-I block. Also, if it will work which ecu would I use. A P28 or the OBD-II ecu.
Re: Real Quick Question (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">yes it will work fine.. use a P28 .. do you have teh whole motor or just the head?? or you just getting info?</TD></TR></TABLE>
It won't work fine....well it will, but he'll need to use an OBD-I dizzy and injectors.
Re: Real Quick Question (Syndacate)
Well I can get ahold of the complete engine, but it has a spun bearing so in the mean time I heard that if I put that head on my block, with the metal head gasket I can get a higher compression. Or was it the other way around. Oh well either way. I do believe that I am going to send the y8 block out to get hot tanked, and also get the crank balanced, recut, and knife edged. Going off of what you said, is it possible to use the complete y8 with a P28 and the obd-1 dizzy and injectors. Also, I am planning on going on boostn in the near future and am wondering if 550cc injectors off of a 1987 supra would work or would i need a resistor box. I am not sure of the impedance on those injectors. Just wondering if anyone knew off hand.
Re: Real Quick Question (turbovybez)
Sorry. I really thought it was only going to be one question. Just want to know which timming belt i shoudl use. Someone told me that I need to use the timing belt for the water pump I am using. i.e. a DX water pump will use a DX timing belt for this swap. Just wondering if that is correct if not can someone point me int he right direction.
whereiscarmensandiego
13
11-07-2008 08:37 PM
trecool44
05-24-2006 10:07 AM
z6 block...what NON vtec head to use to be compatable with arp head studs, and can i use the p06 ecu
19civiclx95
10-25-2005 04:59 PM
