Which Trans Is LSD????
Unceasing Measure
The bottom is, I dunno about the top...can you get another picture? If there's not a diagonal bar hanging in the middle of the line of sight, it's LSD - or that's my experience anyhow.
Ummm mine looks like the top one. And you can see thru it but that little ring is there. Its a Cable Y1. So i wanted to know. And no theres no bar anywhere.
What if i just turn the input shaft. I cant get any axels in there at this time. If i turn the input shaft which way should the axle holes goes.
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">they are both LSD, just differant types. </TD></TR></TABLE>
that's the same thing i see as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H9Omega »</TD></TR><TR><TD CLASS="quote">The bottom is defiantely LSD. Now your's try putting the axles inside, and spin them if they rotate the same direction than yes, it is equipped with LSD.</TD></TR></TABLE>
rotating the axles or wheels is a false way to tell if the tranny is equipped with LSD.
the true way is looking for the bar that runs through.
