help asap
NO VTEC
i have a B20b/b16 head conversion................now there are a few problems.
the problems:
1.Redline is 7500rpm
2.vtec not engaging, we checked to solenoid and thats working ( so we not sure y vtec not engaging bcaz the speed sensor also work)
3.Whenever its in third gear and throttle is fully depressed, check light comes on ! (we have to turn the car off & restart it, to clear the light)
i jus got the car & need to have these issues resolved
NEED TO KNOW THE POSSIBLE CAUSES ASAP !
Modified by speedline r32 at 5:41 AM 5/30/2007
the problems:
Re: NO VTEC (gezzuzz)
well first and foremost all the stickers that indicate the type of computer in the car hav been removed
anyways we tried another ecu....no vtec
wen the car is off, we manually triggered the solenoid, and it opened
but whenever the car is on(throttling) it does not open when we trigger it
also tried a type r solenoid same thing.......
we also tried cleaning the solenoid
no result
check oil pressure, and it was fine
we even changed the oil
tested the wires in the loom for continuity, it also was fine
hence haffi pull up head 2moro fi kno wah gwan
no result
Gridlock
07-06-2007 10:46 AM
CALIdelsolSIR
11-08-2005 02:35 PM
