Why the hell are my brakes so soft still?
Old 05-31-2007, 10:47 AM
Civicman86's Avatar
Default Why the hell are my brakes so soft still?
I have bleed the system 3 times now. And the pedal still feels soft. It is drivable but definatly would not work well when I autocross.
Here is exactly what I did:
1. I jacked car off the ground.
2. Took all wheels off.
3. Used piece of vaccum tube that fit tight over the bleed valve.
4. Filled a water bottle up with about 2" of clean brake fluid.
5. Put other end of vacuum line into the bottle and submerged it in fluid.
6. I then had someone sit in the car pump the brake pedal 3 times and hold the pedal down as far as it would go.
7. I then opened the bleeder valve. When the person in the car told me when the pedal went to the floor I closed the valve up.
8. When it was closed I told the person in the car they could let the pedal go and repeated the process.
I did this process each time until there were no more bubble coming out of the line. Order I bleed them was PR, DF, DR, PF. Also after about four repetitions of the above process I added clean fluid to the reservoir. The reservoir never got low to the min line (in fact it i don't think it got below the half way point between the max and min lines)
Also I don't think it makes much difference but I just did a disk conversion on the back of the car (that is why I am doing this).
Old 05-31-2007, 10:58 AM
sol2hatch's Avatar
Default Re: Why the hell are my brakes so soft still? (Civicman86)
Make sure you start at the farthest point from the resevoir, the passenger rear, then the other side, then the passenger front, then the driver front last. Also, your disk conversion is going to change your pedal feel. Look into getting a different prop valve.
Old 05-31-2007, 11:10 AM
Civicman86's Avatar
I'm using the Si 4040 prop. valve.
I did passenger rear then driver front (diagonals). then driver rear, pass. front.
Would that really make that much of a difference? I had a feeling it would be different but I know just by feel that its not right, it defiantly wouldn't hold up to my autocrossing.
Old 05-31-2007, 11:28 AM
instructor74's Avatar
Default Re: (Civicman86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">I'm using the Si 4040 prop. valve.
Would that really make that much of a difference? I had a feeling it would be different but I know just by feel that its not right, it defiantly wouldn't hold up to my autocrossing. </TD></TR></TABLE>
You have it in the right order. The brake system is tied rr to lf and lr to rf in case there is failure in one of the lines or calipers so you still have some braking ability with a front and a rear brake
Old 05-31-2007, 11:42 AM
Luserkid's Avatar
Default Re: (instructor74)
Make sure the side your working on is more elevated then the others, so the air bubbles can raise to the top. It sounds like you had the car level while you bleed. Also i always finish the bleed with the master cylinder side (driver front) last. Different people different ways though but that always works for me.
Old 05-31-2007, 01:01 PM
Civicman86's Avatar
Well the first two times I bled the system I raised each corner at a time, the last time i just raised the whole car up to make it all go faster. I'm stumped.
Old 05-31-2007, 01:16 PM
TooManyTickets's Avatar
did u change your MC when u did the Disc conversion... if u still have the 13/16 you may want to get the 15/16(good stiff pedal) or the 7/8 (Still good)
Old 05-31-2007, 03:09 PM
Civicman86's Avatar
Default Re: (TooManyTickets)
I'm still using the stock EX MC (13/16 i think).
Old 05-31-2007, 05:15 PM
Civicman86's Avatar
OK so the EX MC is 7/8 so I should be good with that. I'm not hardly getting any brake pressure until like half the travel of the pedal and even then I don't think there is enough to lock the brakes up.
I'm also thinking maybe when I changed the prop valve that there is still air way up in the lines. So maybe it take a long time to get the air all the way down the lines? Any comment on that theory lol?
Modified by Civicman86 at 6:34 PM 5/31/2007
Modified by Civicman86 at 9:47 AM 6/2/2007
Old 05-31-2007, 09:21 PM
Btw what car are the brakes from? if its an Integra.. what MC did the integra have?
If you not happy with where the brakes engage it sounds to me like a MC issue.. now if they were soft then i would think that air would be the problem.
Old 05-31-2007, 09:37 PM
hondamark35's Avatar
i hear you on the bleeding it a few times but since it is still soft i would just bleed it untill you use a full master cyl. resvr. (obviously refilling when needed) you can just leave the bleeder screw open into your catch can with the hose and let a friend pump the pedal up and down untill you need to refill or move on.
if this doesn't fix it double check for leaks and get used to the feel.
Old 06-01-2007, 11:38 AM
Civicman86's Avatar
Default Re: Why the hell are my brakes so soft still? (hondamark35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamark35 &raquo;</TD></TR><TR><TD CLASS="quote">i hear you on the bleeding it a few times but since it is still soft i would just bleed it untill you use a full master cyl. resvr. (obviously refilling when needed) you can just leave the bleeder screw open into your catch can with the hose and let a friend pump the pedal up and down untill you need to refill or move on.
if this doesn't fix it double check for leaks and get used to the feel.</TD></TR></TABLE>
I think I might try this.
Brakes are from a 2000 Si which I believe also uses a 7/8 MC.
Old 06-01-2007, 01:12 PM
Agent_EM1's Avatar
Same thing happened with me.. EXACT same thing... I had SI rear brakes installed on my old OO civic EX... The guys told me they forgot to install something... I think it was a cylinder or something... Proportioning valve? I forgot...
Old 06-02-2007, 08:48 AM
Civicman86's Avatar
I got the 4040 prop. valve. (At least that is what I bought). How can I tell if it is the 4040 and not something else? Anyone know?
Old 06-02-2007, 09:06 AM
hall97civic's Avatar
you need to bleed the brakes in the order farthest from the mc, so pr, dr, pf, df. You very well could have some air bubbles from putting in the proportioning valve.
Old 06-02-2007, 09:53 AM
JDM-EJ698's Avatar
Default Re: (hall97civic)
I think you have a lot of air in the system still.
Old 06-02-2007, 12:54 PM
Civicman86's Avatar
Alright I think im just going to bleed them again. Ill just keep pumping fluid through the system even if there are no air bubbles.
Old 06-02-2007, 01:30 PM
unbelievableEG's Avatar
My coupe is having this problem also. Ive bleed the breaks like 3 times now and adjusted the rear shoes but still extremely shot.
I think the master cylinder might just be shot.
Old 06-05-2007, 10:03 AM
94 Supra TT's Avatar
I've had the same problem.
I replaced calipers, pads, 2 MCs, and switched to stainless lines. And still could not get the car to slam.
Must of bleed them 15 times or so, using two man method.
Only thing I could get to work was to make my own pressure bleeder.
https://honda-tech.com/zerothread?id=1975987
Now my brakes bite hard, and I'm still sporting drums.
Old 06-05-2007, 10:16 AM
madpipr's Avatar
Default Re: (94 Supra TT)
air bleed them
open up jack up the rr, then open up the valve. once you start to get fluid go to the next wheel. do that for all the wheels. once all the wheels have fluid coming from them when you open the valve, bleed them again with the 2 man method.
if that doesnt work, go with the master cylinder. if you are using the 4040 then maybe you have a seal going bad in the master cylinder? make sure the brake booster is still connected to vacuum or isnt leaking anywhere also.
prodjay10
05-02-2016 07:25 AM
TravisCadello
10-29-2008 07:12 AM
StatGSR
09-29-2005 08:41 AM
Mattyg2
09-15-2004 06:41 PM
Lei Siew Long
09-30-2001 07:08 PM
Quick Reply: Why the hell are my brakes so soft still?
