oil pump question?????
Re: oil pump question????? (Luserkid)
Depending on what year the B16 oil pump is from and what year the GSR block is from, swapping the oil pumps could require swapping lower timing belt covers for proper coverage of the pump area. Just something to check out. I put the ITR pump on my 2nd gen B16 and bought the lower timing cover for a 00 Si and looks like it was meant to be there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Yes but youll have to use a B16 timing belt if you use the water pump. </TD></TR></TABLE>
didn't think you could use a B16a belt with a B18B/C block since the blocks are taller
Re: oil pump question????? (germanegturbo)
ok its a 2000 gsr and a 1999 b16...also, im gonna put the b16 head on the gsr block..will that affect ne thing?
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">^...all obd2 oil pumps are the same</TD></TR></TABLE>
Thats where I assumed the difference occurred, primarily because of the CFT sensor, but I wasn't sure and didn't want to say that unless I was sure. I just knew I had to swap lower covers when I went ITR pump on my B16. Thanks for the info!
Dead CIVIC
15
03-02-2008 08:47 AM
