Seal Rubbers for the Hard Top
Hello,
Does anyone knows a web site where i can order the 4 Seal Rubbers Pack for the Hard Top of Del Sol 1992?
I hope my definition of what i want is correct.
Thank you all in advance..
Antonio
Antonio
Re: Seal Rubbers for the Hard Top (apaiva)
I assume you want to change the seals because of leaks?
If that's the problem, I'd suggest you adjust the windows and follow every other tricks available out there. Might save you 500$.
Re: Seal Rubbers for the Hard Top (blaze_125)
my father autobody work and when i just bought my sol bout six months ago my top was leaking also and all we did was pulled the door panels off adjusted the windows one day when it was raining and pulled out of the shop to make sure the leak had stoped took a few times to get it right. now the only time it leaks is when i pressure wash it and then its just a few drops of water on the inside of the glass its not even enough to get on the seats or floors
Re: Seal Rubbers for the Hard Top (rebel842001)
Thank to you all for your help,
But i have leaks and also a lot of noise of rubber and metal, and rubber and window, because the rubber have allready 15 years, they are really bad now.
And the 1992 Del Sol had a origin problem, the front rubber of the roof lets some leaks inside the vehicle. So i think the only way is really to change it.
Thank you
Antonio
Thank you
Antonio
http://www.slhondaparts.com/br...PANEL
85191-SR2-033 WEATHERSTRIP, L. ROOF SIDE $72.08 $16.90
85141-SR2-033 WEATHERSTRIP, R. ROOF SIDE $68.81 $16.14
75826-634-300 SEAL, INSIDE PANEL (15MM) $1.28 $0.30
85105-SR2-010 SEAL, ROOF SIDE FRAME $4.59 $1.08
Modified by blaze_125 at 9:53 AM 6/4/2007
Sol to Sol
Well, Blaze answered your question. That site is pretty much the same.
BUT, if you want to save $500 like they said above, then all you need is a silicon grease 'tube' (Dielectric grease, like the stuff for spark plugs, but in a large tube) and rub it on the seals. It will soak in and the seals will 'puff out' thus reducing, or stopping leaks and squeaks.
I think there is a link to the tip on the FAQ page.
I tried this, and it worked great! Just have to redo it about every 6 months, like you would to maintain new seals anyway.
Good luck!
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apaiva »</TD></TR><TR><TD CLASS="quote">I'm sorry solfly but can you tell me the area of the site i will find what i want
And the exact name please?
Thanks
If I change my name to solfly, will you read my god damn post and stop asking the question?
Thanks
Thanks
Get off the crack pipe and read the post...
4 of the same question and still you don't get it
Thanks
Neptronix
13
01-16-2012 05:12 AM
