Turbo b16 help
Turbo b16 help
i have a b16 with lots of work done and i want to turbo it...it has JE pistons with 11:1 compression can i still safely turbo this or should i buy lower compression pistons? please let me know what you all think thanks
Re: Turbo b16 help (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Yes you can. But make sure you tune it accordingly.</TD></TR></TABLE>
Yeah, with the right tune on it should kick ***.
What kind of head work is done to it?
Re: Turbo b16 help (Formula94)
im running a jdm b16a with 10psi on it with the stock internals and its tuned with hondata s200. corret me if im wrong but i think the b16 stock comp ratio is like 10:1 so you should have no problem with boosting it since you already have upgraded pistons but if u plan do put a lot of boost to like over 10psi i would recomend the you look to upgrade your rods to, to keep from bending them
hotimportcrx
03-05-2005 05:08 PM
slipstream
11-08-2004 01:36 PM
