Summer coolant, what to use?
Re: Summer coolant, what to use? (_skitzo_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _skitzo_ »</TD></TR><TR><TD CLASS="quote">OEM Honda coolant</TD></TR></TABLE>
/thread
/thread
Re: Summer coolant, what to use? (cheesee)
I would just use a 50/50 mix make sure to use distiled water if oyu make your own. If you are really concerned about the heat in texas you might want to increase the size of your rad if you are still running stock.
Re: Summer coolant, what to use? (mikeycivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic »</TD></TR><TR><TD CLASS="quote">premix are waste of money mix your own</TD></TR></TABLE>
Exactly, its for people who pay 'just $50' for someone to change their oil.
Agreed, you also get more if you use the concentrated one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesee »</TD></TR><TR><TD CLASS="quote">well then what are good brands for non premixed? ill try to get my friend at honda to steal me some coolant...</TD></TR></TABLE> Prestone, Peak, etc.
Re: Summer coolant, what to use? (SiYouLater)
I've always just used PEAK. IF you live in texas, you could just put straight water in it, just don't let it freeze. Water transfers heat better than antifreeze, so if you want it to run just a tad cooler, just put straight water in it. Does it ever freeze in your part of texas?
later
later
Re: Summer coolant, what to use? (hall97civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hall97civic »</TD></TR><TR><TD CLASS="quote">I've always just used PEAK. IF you live in texas, you could just put straight water in it, just don't let it freeze. Water transfers heat better than antifreeze, so if you want it to run just a tad cooler, just put straight water in it. Does it ever freeze in your part of texas?
later</TD></TR></TABLE>
Exactly, you don't need to do 50/50. I would do 75% water to 25% coolant. Or just do all water, cuz like "hall97civic" said water transfers heat way better then coolant.
Re: Summer coolant, what to use? (h2392si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4h »</TD></TR><TR><TD CLASS="quote">I am from vegas use 50/50 its the best way to go use it on boost motors too </TD></TR></TABLE>
LOL that is the dumbest thing I have ever read, I might add that to my sig
Re: Summer coolant, what to use? (hondadriver)
later</TD></TR></TABLE> negative ghost rider. antifreeze/ coolant not only lowers the freezing point of water but it also increases the boiling point of water therefore increasing the amount of heat the coolant can absorb without the water boiling off
edit: want proof here you go
http://autorepair.about.com/li...3.htm
it's the pressure that raises the boiling point I can't comment if the coolant adds to that, but I have heard of race cars running water only. the bottle of water wetter also states it can be run alone with water. if I lived somewhere warm I would be tempted to run like that
Modified by gtlaw1 at 4:23 PM 5/30/2007
Re: Summer coolant, what to use? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile »</TD></TR><TR><TD CLASS="quote">
Exactly, its for people who pay 'just $50' for someone to change their oil.</TD></TR></TABLE>
They exist? damn
They exist? damn
just make your own 50/50 mix
LOL that is the dumbest thing I have ever read, I might add that to my sig</TD></TR></TABLE>
stfu i wouldnt be talking https://honda-tech.com/zerothread?id=1972771
