H-brace?
Re: H-brace? (Crx_Civic)
your right on the dumb ? part. anything that will stiffen the chasis of your car is going to help the handling you might not be able to tell a big difference with just the h brace but if you was to have front and rear upper strut bars and even a lower rear cross bar you should be able to tell a sunficant difference in the handling of your car. but you also need to remember that your cars handling will also be affected by your tires and even the camber and toe setting on the alignment. hope this helps
