CEL Code Help
Old May 31, 2007 | 07:53 AM
rc2o6's Avatar
Default CEL Code Help
Hey everyone. i have a obd2 1998 civic dx hatchback with an LS engine from a 98 integra (obd2). my check engine light came on last night and the speedometer instantly stopped working but everything else works. i checked the ecu for the codes with the pin and it came up with the numbers 17, 20, 41, and 65.
I know that:
- 17 is the VSS - vehicle speed sensor
- 20 is the electronic load detector ?? anyone know what that is or how to fix it??
- 41 is the primary oxygen sensor heater
- 65 is the secondary oxygen sensor heater wire (black wires)
my buddy and i are going to the junkyard later to get a vss n O2 sensors from an Ls but we have no idea how to fix the electronic load detector.
Any help or advice would be greatly appreciated. thanks all.
Modified by rc2o6 at 2:41 PM 5/31/2007
Old May 31, 2007 | 01:24 PM
rc2o6's Avatar
Default Re: CEL Code Help (rc2o6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rc2o6 &raquo;</TD></TR><TR><TD CLASS="quote">Hey everyone. i have a obd2 1998 civic dx hatchback with an LS engine from a 98 integra (obd2). my check engine light came on last night and the speedometer instantly stopped working but everything else works. i checked the ecu for the codes with the pin and it came up with the numbers 17, 20, 41, and 65.
I know that:
- 17 is the VSS - variable speed sensor
TTT
Old May 31, 2007 | 01:32 PM
97Ej6mike's Avatar
I know that:
Vss is VEHICLE speed sensor, lol.
Both your O2 sensors are shot it seems, get those replaced.
As for your code 20, sounds like maybe its an alternator problem. Get it checked out.
Old May 31, 2007 | 06:52 PM
rc2o6's Avatar
ttt
Old Jun 1, 2007 | 02:57 PM
rc2o6's Avatar
any help? thanks
Old Jun 1, 2007 | 03:00 PM
Eran's Avatar
HT White Ops
the ELD is located under the engine bay fusebox. It's usually not defective, and the problem is caused by wiring problems. If you can get it cheap, you can try replacing the fusebox, but it may not be the fix you're looking for.
I find it less than coincidental that you have both O2 sensors, the VSS, and the ELD click over at the same time. Chances are there's a fuse blown somewhere, or a short in the wiring.
I've actually heard of a lot of ELD problems stemming from bad O2 sensors or an O2 sensor wire grounding out and sending all sorts of weird signals. Replace both your O2 sensors, and double check that there are no bare spots or breaks in your wiring harness for the O2 sensors.
Old Jun 1, 2007 | 03:20 PM
pdiggitydogg's Avatar
^Agreed
that series of codes is common with a blown alternator fuse (under the dash)
or
the main wiring harness has made contact with the intake manifold
Honda released a service bulletin about this, but somehow I cant seem to find it now. Its getting more common as the cars get older and the harness cover wears down.
Old Jun 1, 2007 | 03:21 PM
Eran's Avatar
HT White Ops
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">that series of codes is common with a blown alternator fuse (under the dash)
or
Honda released a service bulletin about this, but somehow I cant seem to find it now. Its getting more common as the cars get older and the harness cover wears down.</TD></TR></TABLE>
Exactly what I was talking about, but worded far better.
Old Jun 1, 2007 | 04:48 PM
rc2o6's Avatar
thanks for the information. i'll check on that .
ajbreezay
Nov 8, 2007 04:53 PM
Sic_DA_Nine
Nov 4, 2007 06:19 PM
killaj12
Mar 5, 2007 04:16 AM
integ401
Sep 18, 2006 02:01 PM
c1civic
Dec 6, 2004 09:40 PM
