Del Sol Cruise Control/Switch Wiring Questions
i was wondering if any-1 knows which color wiring or order of pins is used for the power and ground for the cruise control switch that is above the cluster. Basically theres quite a few wires that are used on all of the switches such as the CC but i have no idea which is for power and which is ground. It is no longer connected and power steering has been removed. Im seeking to use the CC switch for other means, just trying to figure out which color is power and which for ground and ill be all set. For reference im looking to use the clutch switch for my launch control and use the cc switch to enable/disable the switch. Problem is theres 5 or 6 wires coming off the switch and i dunno which color wire is ground, or power.
My same question also applys to the jdm switches that fit in the rear bin locations, i have the "heated" seats switches, they have quite a few pins on them but im not sure which pin is for power/ground and id like to use those for other means as well'.
thanks for your time
Draggin99Si
01-09-2005 07:25 PM
