which a/c compressor 4 b-series swap in eg
put my b16 n my 94 eg si , which compressor do i use on the p30 bracket that works with the stock a/c lines.
Re: which a/c compressor 4 b-series swap in eg (biggdogg)
a 94 up gsr ac compressor will work..cause i am using it..i am running gsr ac compressor and it bolts onto my jdm p30 ac bracket.u just have to modify the ac lines a bit to bolt onto ac compressor.and i am using d series ac belt without any pulley cause ti is tight enough. u have a jdm sir II swap ,right?
Modified by crazyguy at 7:23 AM 9/10/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggdogg »</TD></TR><TR><TD CLASS="quote">stock sway on my 94 si eg</TD></TR></TABLE>
sorry i meant to say jdm b16a sir II swap
Re: which a/c compressor 4 b-series swap in eg (crazyguy)
you need the b16 delsol ac bracket and you can bolt up the d series compressor right up and use all your d sereies a/c stuff...but i forgot the number of the bracket..
why am i still shocked when people talk about this?
if you want to re-use your dseries ac compressor you can, this way you won't have to release the freon, you can use the del sol bracket, but it's twice as much as the CRV bracket which is the SAME.
so go get a ac bracket from a CRV and you need the adjustment pulley for it as well, bolt your d-series ac compressor to it, and use your stock d-series belt.
if you want to deal with releasing freon and possibly increasing your chances of getting cancer later in life, then go for it.
SpiderBall
05-03-2008 04:38 AM
