Hard into 1st gear
Hard into 1st gear
I have a 1995 Civic EX manual that does not like to go back into first from a stop, and sometimes even has to go into third and then first. It has a brand new clutch kit, I do notice that the shifter is a little bit sloppy. Any ideas? Thanks
Re: Hard into 1st gear (molobo)
make sure the clutch and pressure plate are alligned right?
maybe you screwed up a synchro?
maybe you just fucked up the tranny?
after market exhaust, after market shifter?
help us, help you.
help us, help you.
Re: Hard into 1st gear (forcefedferio)
thats just the way some trannys are... its not a bad thing its just the syncro isnt made to syncronise a non moving car..... thats why you gotta put it in a diffrent gear first.. same with reverse sometimes (even tho reverse is non syncrod) the gears dont always line up and you gotta syncro it (put it in a diffrent gear to syncronise it)
Re: Hard into 1st gear (JdelMsolG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdelMsolG »</TD></TR><TR><TD CLASS="quote">make sure the clutch and pressure plate are alligned right?
help us, help you. </TD></TR></TABLE>
Car is bone stock.
Thanks all for the replies, the bushings could def use a replace, but i figured it would mess with all gears rather than just first if it was going to be a problem.
Car is bone stock.
Re: Hard into 1st gear (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">If the clutch is new, and was installed properly, it sounds like a transmission issue. </TD></TR></TABLE>
Every time I had a clutch that was old, I would have the first gear issue. D series trannies are weak from the factory, so something is probably worn out, or bent.
Re: Hard into 1st gear (Danronian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian »</TD></TR><TR><TD CLASS="quote">
Every time I had a clutch that was old, I would have the first gear issue. D series trannies are weak from the factory, so something is probably worn out, or bent.</TD></TR></TABLE>
Yea, i know ppl that go thru them like their nothing. Personally ive only had one go once, and that was that, but ive installed many for/with friends, and their a dime a dozen.
Spinks
Honda Civic (2006 - 2015)
11-23-2010 06:01 PM
Inextricabledrvr
04-13-2005 10:02 AM
