Failed Emissions in NJ, High NOX
I was wondering if anyone had any suggestions besides the usual. I have a 95 Civic DX with an JDM OBD1 B16. HC CO was fine but NOX was 1522, when passing is 1372. I use the O2 sensor from the engine, converter from the DX, stock intake and exhaust. My timing may be off a bit. My old EVAP System had a port on the DX manifold which doesn't exist on the B16 so I never hooked up the EVAP. Could that cause high nox? Well, If anyone knows something about this I would appreciate some advice. Thanks
Re: (myrrh81)
Just retard your timing (move the dizzy twords the front of the car) and goto inspection. Your car will run like **** for the time but it will lower your nox alot. Then get home and move the dizzy back to where it orgionally was. Use a timing light when moving the dizzy back for the correct timing.
94 GSR Similar Problem
I have a 94 USDM GSR swap (b18c1) in my 92 hatch and just failed NJ emissions for high NOx.
I have the USDM p72 computer and have passed twice before.
I will adjust my timing, it was a little off, but i'm not sure if this will make that much of a difference. what are other solutions to lowering NOx? Please note that it passed in the other two categories, so ONLY NOx was high.
Thanks
Thanks
Re: (JayKayNidas)
What does HEET stand for?
How would COOLANT affect the o2 sensor/cat?
-- Plan to adjust timing, change the plugs, etc and oil but still not sure if it'll bring me down enough.
This may seem like a really simple question but how do the o2 sensor and catalytic converter affect the level of NOx? I thought they had more to do w/ the level of HC and CO...
Which is more likely o2 sensor or cat or just timing?
racebum
01-14-2009 01:48 PM
