Check timming w/ aftermarket pulley
Re: Check timming w/ aftermarket pulley (blue_hatch)
crank or cam pulley? if it's a crank pulley it should still have timing marks on it....if it's a cam pulley then there should also be markings for 0 degrees which would be base timing.
if there are no markings, pull spark plug number one, drop in a long dowel, turn the crank until tdc.
Verify its 1 tdc with the dizzy rotor (pointing to contact 1) or cam markings O> <O
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedferio »</TD></TR><TR><TD CLASS="quote">crank or cam pulley? if it's a crank pulley it should still have timing marks on it....if it's a cam pulley then there should also be markings for 0 degrees which would be base timing.</TD></TR></TABLE>
its the crank pulley but has no markings on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">if there are no markings, pull spark plug number one, drop in a long dowel, turn the crank until tdc.
Verify its 1 tdc with the dizzy rotor (pointing to contact 1) or cam markings O> <O</TD></TR></TABLE>
thanks thats what i was looking for
spyderracing
14
09-26-2004 09:10 AM
