obd1 gsr into dx??
obd1 gsr into dx??
alright guys i put in a 95 obd1 gsr into my 94 dx hatch ...what do i need to wire up besides vtec stuff...do i have to wire up iab? or knock sensor?..this one dose not have the wierd gsr mani that looks upside down..its a regular one..please help me out tried searching but wasnt working..
Re: obd1 gsr into dx?? (305accord)
if your running a chipped p28 you just have to wire up the vtec solenoid and pressure switch if your running a stock computer your gonna run into problems cause the computer is gonna look for the iab in the stock manifold and its not gonna be there
Re: obd1 gsr into dx?? (hybridmath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmath »</TD></TR><TR><TD CLASS="quote">if your running a chipped p28 you just have to wire up the vtec solenoid and pressure switch if your running a stock computer your gonna run into problems cause the computer is gonna look for the iab in the stock manifold and its not gonna be there </TD></TR></TABLE>
How can he run into problems with the p28 ECU if it doenst look for IAB's to begin with? Only the p72 does. You will need the P72 ECU, and to wire VTEC and the IAB manually -OR- get a GSR wiring harness as well, may save you some time if its easy to find one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 305accord »</TD></TR><TR><TD CLASS="quote">alright guys i put in a 95 obd1 gsr into my 94 dx hatch ...what do i need to wire up besides vtec stuff...do i have to wire up iab? or knock sensor?..this one dose not have the wierd gsr mani that looks upside down..its a regular one..please help me out tried searching but wasnt working..</TD></TR></TABLE>
Aftermarket manifold maybe?
I dont think it will require the IAB if that is the case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 305accord »</TD></TR><TR><TD CLASS="quote">i have the complete gsr harness and p72 ecu...</TD></TR></TABLE>
Then you are all set to go
