d16z6= 1 plug from harness has nowhere to go!!!! help.
description::
car: 94 civic vx vtec-e
motor swap: 95 d16z6 from del sol si
wire harness: 94 vx
ecu: p28-l01
my problem i have transferred the vx harness on to the d16z6 block and i have attached all plugs except 1. it is the one that is by the vtec solenoid. i think its called an evap. will this bring me any problems or cel?
another issue is i have the upper header portion but not the bottom part, what can i use to replace that? do i have to use the ex header downpipe or something?
can i use my vx exhuast for this swap? any help would be greatful.
wire harness: 94 vx
ecu: p28-l01
Re: d16z6= 1 plug from harness has nowhere to go!!!! help. (kajornklin)
I'd say as long as you are using a P28, you'll be fine. If the Z6 has no provision for that plug, the P28 will not have the pin active for whatever that is, either.
krysted9354
20
12-14-2008 02:31 PM
spooolin
08-08-2006 08:49 PM
112480
14
04-10-2004 03:48 AM
