ok so
ok so
i was driving down the road in my 92 civic hatch the other day,and it just stopped going.i would put it in gear and let out the clutch,and the engine would rev up,but when i hit the gas, absolutely nothing.it will not start now, and it IS getting spark and fuel.i know it needed rings because it did smoke some when i would get on it, do you think my problem is the rings completely gave out, or could it be something else?this has had me baffled for the last couple of days,and any input will be greatly appreciated.thanks
Re: ok so (nate_deezy)
year? make/model? miles? need some more info, bud
in the mean time, it almost sounds like a clutch issue if you put it in gear but it didn't go anywhere. does it start/run?
ok i wasn't sure if it was running or not. i dont know how tech-savvy you are, but you might want to check your ignition system for spark. alot of times when a coil or ignitor goes up, the car will just shut off like that. its happened to me before. but the car started up after it had cooled down a bit.
first step would be to take your distributor cap off and look inside to see if there's any corrosion in there. if so its possible you might need a coil or ignitor.
if the ignition system is ok, you need to look at your fuel system.
Re: ok so (na+b18c_hatch)
ive done all of that.it is getting spark because i took the wires off and cranked it and i got an arc jump.and on the other hand im pretty sure its getting fuel because i took out the plugs and they were wet.
and also i just put a brand new distributor,dist cap,rotor button, plugs and wires not even a month ago.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_deezy »</TD></TR><TR><TD CLASS="quote">and on the other hand im pretty sure its getting fuel because i took out the plugs and they were wet.
ok, you're plugs being wet is NOT a good thing. that means they're fouled. if they become submerged in fuel they will not fire correctly.
good point.i didnt even think about that haha.thanks for your help man.
honestly i dont even think im gonna worry about trying to do anything with this motor tho because it has 200k + miles and its slow as [freak]in day.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_deezy »</TD></TR><TR><TD CLASS="quote">honestly i dont even think im gonna worry about trying to do anything with this motor tho because it has 200k + miles and its slow as [freak]in day.</TD></TR></TABLE>
then i would say go cheap and swap in a b16a2. you can get a complete swap for around $1500 (+/-) depending on where you get it.. not much more than it would cost to overhaul your current engine. you can search honda-tech's 'for sale' forums, and/or try this site:
http://www.hmotorsonline.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate_deezy »</TD></TR><TR><TD CLASS="quote">alright thanks for all the help man</TD></TR></TABLE>
i didn't do much lol.. but sure bud.
Beegee208080
11
09-20-2013 01:02 PM
MaliciousCivic
33
07-09-2008 11:39 AM
hondaracin24
01-18-2005 07:31 AM
