HELP: TIMING BELT SLIPS
hey i just replaced my timing belt and when i started the car the belt was slipping off the cam gear.....any reason why???
Re: HELP: TIMING BELT SLIPS (150sol)
the cam gear doesn't have a washer, only the crank. as to the slipping how is the belt tension?
id assume you just don't have enough tension on the belt and it ripped the belt over a tooth...
with enough tension on the belt it shouldn't slide off the cam gear either.
Re: HELP: TIMING BELT SLIPS (addiction2bass)
I know the cam gear doesn't have a washer, but if you don't have it on the crank it will ride off onto the balancer and you'll see it off at the cam.
prolly because u didnt tension the belt right when u put it all on and with the tensioner lose u take a socket and rotate the crank 3 teeth to put tension on the belt then tighten the tensioner pulley.
realis9
08-26-2007 12:52 AM
-Gambit-
11-13-2005 04:13 PM
