B16A 92-95 (SiR-II) swap???
Will a B16A 92-95 (SiR-II) bolt straight into a 94 civic?? what all do i need.. i tried researching but i have had no luck.. i didn't know since it was out of the jdm civic if it would bolt right in without swap mount??? I'm pretty clueless about the B16???
Re: B16A 92-95 (BlueIntegraBoy)
what about the shift linkage?? and on my D the is a big *** mount in the bak like a brce or something should the b16 come with that?
Re: B16A 92-95 (greeneg1213)
B16A 92-95 (SiR-II) Complete Change Over
Price: $ 2250.00 Plus shipping and handling
Availability: In stock and ready to go
- Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
This is everything that comes with it
- Motor
- ECU (P30)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
my car doesnt have a knock sensor rite now and i dont believe the b16 has one eather, and the plugs are the same or is internal wiring??
Modified by greeneg1213 at 1:56 AM 7/15/2008
https://honda-tech.com/zerothread?id=644434
there are a couple things to help you out... use the FAQ at the top... and search too...
Re: B16A 92-95 (riceburnerryan)
by the way, b16's dDO have knock sensors, any dual cam vtec is gonna have a knock sensor, and it doesnt depend on the trim of your car whether itll be plug and play, it depends on its place of origin eg> canada, usa, or japan. candaian civics 94 and down, no matter the trim, have vtec in the wiring.
Re: B16A 92-95 (longshot)
but the jdm b16 comes wwith a wiring harness shouldnt the knock sensor already be wired up?? and im using the p30 that comes with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by longshot »</TD></TR><TR><TD CLASS="quote">by the way, b16's dDO have knock sensors, any dual cam vtec is gonna have a knock sensor, and it doesnt depend on the trim of your car whether itll be plug and play, it depends on its place of origin eg> canada, usa, or japan. candaian civics 94 and down, no matter the trim, have vtec in the wiring.</TD></TR></TABLE>
Incorrect, all 92 Civics are prewired for VTEC, after that year only the EX, Si, and VX are wired for VTEC.
Seagull Management
Yeah, '92 civics only are prewired for vtec at the shock tower plug. To greeneg1213 you wont be able to use the harness that comes with the engine. its off a right hand drive civic and most of its flipped around the wrong way, generally when doing an engine swap you reuse your original engine harness and add the pieces that are missing from the harness that comes with the engine, sometimes you will need to lengthen wires for certain sensors as well, but general rule of thumb is reuse original harness.
Re: (94EG8)
ok thanks so the only thing i goda do is wire up the knock sensor, with that diagram i should be able to do fairly easy... im also doing a wire tuck too in the process off the swap while i got my d out im going to shave the engine bay.
Seto-Initial-B
07-26-2006 10:31 AM
The Alchemist...
05-02-2005 03:49 PM
hondahatch741
11-03-2004 03:20 PM
