Do JDM ITR Rear Seats Fit???
Would a set of JDM (no center plastic tray) ITR Rear seats fit it my 92 Civic Hatch. They're direct bolt up if I'm not mistaken but would there be any gaps or anything loose?
Re: Do JDM ITR Rear Seats Fit??? (Deadlock281)
yes they will, but you will have a gap on both sides just like the dc2's due to the fact that they are the same size with or with out the plastic
Re: Do JDM ITR Rear Seats Fit??? (jwerks)
Will they lock into the hooks and how big a gap would there be?? ALSO waht would fit perfectly? If anything...
Re: Do JDM ITR Rear Seats Fit??? (slvrcvc93)
i know for the coupe you need the coupe ITR top seat and the sedan bottoms and they fit a lot better. not sure if its the same for the hatch though.
Re: Do JDM ITR Rear Seats Fit??? (EcivicG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EcivicG »</TD></TR><TR><TD CLASS="quote">i know for the coupe you need the coupe ITR top seat and the sedan bottoms and they fit a lot better. not sure if its the same for the hatch though.</TD></TR></TABLE>
wrong that setup is for the hatchbacks. For the coupe u would need both the sedan seat parts becuz the civic coupes seat fold down as one like the sedan does. you will have a gap big enuff where u can see what is underneath the seat at the sides. only way to fix that is to custom something to block the sides out. the hooks willl go in but the back piece where the 10 bolt goes will not line up with the hole.
Hmmm guess I'll have to make some calls and get some connections with an upholsterer, because eventually I'm gonna want that black with red stitching look.
Thanks for all the help, um... has anybody ever used that fabric paint that I've seen at the store????
Re: (Deadlock281)
yup, you'll need the 2-door top pieces (back rest) and the JDM ITR 4-door bottom bench to have almost no gap at all.
here's a pic of mine if you're curious how it looks:
Re: (Mashimaro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mashimaro »</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
Nice interior! Got anymore pics? That setup is the perfect setup.
Itr's for my hatch:
Am going to mode the bottom so they fit better.. If you just put them in now, there will be a gab on 5 cm from the bottom to the back..
My buddy have made his to fit:
Re: (slvrcvc93)
Awesome set ups guys! So i need the back from a two door and the bottom from a JDM four door??? I'll just have to start looking around. First comes my GS-R brake swap! Then Omnipower Coilovers! Then interior and I'm done.....for now.....
Re: (Deadlock281)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deadlock281 »</TD></TR><TR><TD CLASS="quote">Awesome set ups guys! So i need the back from a two door and the bottom from a JDM four door??? I'll just have to start looking around. First comes my GS-R brake swap! Then Omnipower Coilovers! Then interior and I'm done.....for now..... </TD></TR></TABLE>
yup, that's it!
FYI - the GSR brakes are IDENTICAL to all integra brakes other than the ITR ones...so don't get ripped off if some dood sells you the brakes for more money than they're worth just cuz they came off a GSR.
yup, that's it!
RyCeRoCkeTz
08-30-2005 03:08 AM
JDMvtecDRAGSTA
06-27-2002 11:55 AM
JDMvtecDRAGSTA
10
03-15-2002 06:52 AM
DC2_R
13
03-14-2002 09:22 AM
