Would this prevent me from passing smog?
... my crank sensor doesnt work so i was thinking of doing this
http://technet.ff-squad.com/ckftrick.htm
Re: (Relic1)
thanx.... i was planning on doing it under the dash where its hard to seee .. like right next to the firewall..
Re: Would this prevent me from passing smog? (darksolguy)
Are you going to get the motor barred? Or are you just trying to pass smog? If your just trying to pass smog, they won't look at your ecu to check for tampering. This is just based on my experience of smogging vehicles, all they do is plug in that one scan tool and look under the bay and then the test. If you are trying to bar the motor, I have no clue but I think they would check out your ecu.
Re: Would this prevent me from passing smog? (e90ondubz)
no its my stock motor just trying to pass smog due to reff ticket....
bro just an FYI i wouldnt do that trick... I did it and less then a week later another CEL appeared that would stall every time i stopped i undid the trick and it was fine but the crank sensor CEL came back I would do it the day of your car going into inspection then UNDO it when its done and get a new crank sensor they are like 25 bucks and its easy to get to by taking off the left front tire and taking the plastic cover and you can see it and easily reach it...
Re: Would this prevent me from passing smog? (EquipedWithVtec)
ohh damn.,. for reals.. thanx.. good looking out... yeah i think i am just gonna do it that day and hopefullly pass it ... do u knoe where i can get the sensors from?
I dont know why he had those problems, but ive done this on more than 5 cars, and have not had any problems. And never heard of anyone having any problems either. Your choice.
Re: Would this prevent me from passing smog? (lluks_844)
If you throw a CEL its an automatic failure for smog so if it works and doesen't throw a code you should be fine...but why don't you just fix the problem?
Re: Would this prevent me from passing smog? (jdm94ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lluks_844 »</TD></TR><TR><TD CLASS="quote">I dont know why he had those problems, but ive done this on more than 5 cars, and have not had any problems. And never heard of anyone having any problems either. Your choice.</TD></TR></TABLE>
have u seen the diagram up there^ is that the correct way to do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm94ej1 »</TD></TR><TR><TD CLASS="quote">If you throw a CEL its an automatic failure for smog so if it works and doesen't throw a code you should be fine...but why don't you just fix the problem?</TD></TR></TABLE>i wanna fix it but the plug for the crank sensor plug got cut and the plug is lost so i realy dont have a choice and i have to go reff it soon so i dont have alot of time
