Does anybody have a How-to on how to install gauge cluster needles?
<FONT COLOR="royalblue"> Purchased a 96-00 gauge cluster from the dealer, but it does not come with the needles mounted.</FONT>
you purchased the entire cluster or just the gauges in the cluster?
I've only seen one brand new cluster from honda and it had everything in tact. Purchasing the gauges separately is a different story.
the needles are calibrated, especially the tach and speedo. The temp and fuel gauges are a lot more of a course scale so precise accuracy isn't really needed.
install the cluster without the needles, leave off the plastic cover so you can get to the gauge faces.
tach - start car let idle until fan turns on and off, install needle pointed at 800RPM
temp gauge - at same time install needle pointed at center of travel
fuel gauge - fill tank and point needle just over the F line
speedo requires another car to pace with... you see where I'm going with this right?
you can do all of this with a function generator, o-scope and some math to figure out things with the Helm manual. But the first method works fine and you don't have to have expensive equipment.
Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">you purchased the entire cluster or just the gauges in the cluster?
you can do all of this with a function generator, o-scope and some math to figure out things with the Helm manual. But the first method works fine and you don't have to have expensive equipment.</TD></TR></TABLE>
<FONT COLOR="royalblue"> I'm sorry I forgot to elaborate.. I purchased the Temp/Fuel gauge from Honda. I will try this tommorrow. Also is there anything special that gets them to stay on? Thanks.</FONT>
raverx3m
11-10-2013 08:18 AM
prettysweetcivic
15
12-05-2004 03:59 PM
