best way to flare/roll arches?
alright lads i need a little knowlage from some of the experts! im purchaseing a set of new wheels, but they are stickin out a little, iv a camber kit but id like to keep the camber as neutral as possible so im gettin the loan of a arch roller, my question is this. what is the best way to go about rolling the aches? the lip that turns in from the body, should i first cut it off and proced to flare the arch out? or leve the lip on and roll it out along with the pannel? any help is welcome
Re: best way to flare/roll arches?
it looks cleaner with the lip still there and less chance of a sharp edge to cut a hand or tire. only other advice is buy a heat gun and use it on the paint so it doesn't crack or chip away when the fender starts to move. good luck
na lad i want a nice clean finish, the pipe trick can come out rough enough! thanks bud i was just thinking id get more of a flare if the lip was cut off and grinded back to the pannel, but i guess ill roll it with the lip still on! and iv a heat gun too so hopefully no cracked paint !!
