Oxygen Sensors...
Oxygen Sensors...
Check engine light came on, checked the code and its the 02 sensors. Is one brand better than the other? I see NGK ($150 for both) are a little more than Denso ($120 for both). There is also AC Delco/Standard, Bosch... I know Honda uses NGK plugs. What is recommended? Worth the extra cost? Also can you figure out which one is bad or should both be replaced at the same time? Thanks
Re: Oxygen Sensors...
Get whatever is cheaper for the primary, and forget about the second unless you get a CEL. Then find a way to bypass it. It's only emissions, and some of us don't even run cats, so I view it as pointless.
I think Honda uses Denso O2 sensors from the factory, but NGK will be fine. I think I heard that Hondas don't like Bosch.
1993eghatch
17
01-21-2011 09:22 PM
98IntegraLSNonVtec
08-04-2006 09:18 PM
