Bought a car and have some qestions about it?
93 civic EX
car was a stolen recovery. motor/trans, interior and doors stolen.
My Q is on the motor. Right now it has a Y7 block with a Z6 head in it but the distributor doesn't line up with the 3 bolts. I think its the Y7 distributor and I'm about to replace the timing belt tentioner and set the timing. I was going to put a Z6 distributor on it but I'm not sure if its plug and play or if I'll have to repin the plugs. If I have to repin it can some one give me a link to the info?
Also witch ecu do I need for the Y7/Z6 combo? I want to make sure I have the right one in the car to work the Vtec.
thanks
thanks
Re: Bought a car and have some qestions about it?
Z6 ecu. if the harness is from lets say 92-95 ex coupe that came with the z6 the distributor should plug and play if it isnt you will probably need to repin(I can't help you find info on it at the moment)
thanks
Are the y7 and z6 distributors interchangeable plug wise?
O I bet they left the y7 engine harness one the motor when they put the y7 motor in. that could explain the y7 distributor.
what motor came in the DX and LX models? the y7? I know the y7 in the EK's are obd2 and the z6 I know is obd1 so if thats the case no they aren't interchangeable
ok so yeah if the harness is from a 96-00 dx/lx model car no it won't be a plug and play. GO HERE http://boomslang.us/obd0_1.pdf scroll all the way down to the 6th page very last diagram. It shows you what color the wire is and what function it has for obd0/1/&2 so if you need to rewire thats all you need to use to find out what wire goes where. please correct me if that diagram is wrong.
Its prob not a y7 dizzy and if one bolt dont line up its fine. As long as its at least a single cam Vtec dizzy there should be no problems.
Any Vtec ecu would work. I dont see any problem with you setup
as well as a z6 is obd1 and a y7 is not.
also i think password jdm makes a plug for this, so instead of switching plugs he can just plug it in.
not really, it would be built like a normal mini-me setup with the y8 head, he just needs a sandwhich plate to run an oil line to the head for vtec and obviously get a vtec dizzy and ecu. the y7 block and the y8 block are basically identical.
