hard to go into second gear?
94 si. og motor/tranny. 2nd gear is harder than the rest to go in. doesnt pop out or anything. like i cant slam it in. regular driving is kinda hard too. but not impossible. clutch?
Re: hard to go into second gear?
Odd. If there were I would say synchros,... Have you checked the condition of your shifter bushings? they could just be worn, or falling apart. Other than that I don't know. Good luck.
I would say either your shifter, or just 2nd is pooping out.
Had a somewhat similar problem like that in my old hatch, only it was 1st gear, ended up being the synchros. Then the tranny finally had enough of it and put a big *** crack on the bottem of the tranny.
Good luck
Good luck
Someone makes a urethane set. I have a set in my car and I personally love them. They're a little stiff so it takes a bit of play out of your shifter but is still very smooth. If yours are bad they're worth a shot. only like 12 bux.
miamiboy91
04-16-2009 04:26 AM
msmotorsports
10-17-2005 05:45 AM
