99 civic dx problem
99 civic dx problem
Ok. i just noticed this tonight so dont hit me up with alot of questions until tomorrow. My problem is; i was driving home from work tonight and noticed that ALL my lights were pulsating. so i searched around on here and found a couple things went out and tryed them nothing helped. What i did notice that when the car was running i would take the ground off the battery and it would stop pulsating. any ideas? Thanks for your time.
Re: 99 civic dx problem
Is the CEL on?
Did you replace fuse #15 with a known good fuse? Is the light flickering problem intermittent? If so, you would need to test the alternator when the problem is happening to know if the alternator is the problem.
Does the dash battery/charge light go on while driving?
i did not replace the fuse pulled out to look at and see if bad. light problem happens whenever the car is running. what i meant earlier is that it went away for a bit then came back later in the day.no it does not come on.
sbenoche
06-10-2008 11:00 PM
