EG lower ball joint
Old 02-21-2010, 11:13 AM
mattbatson's Avatar
Default EG lower ball joint
So, I disassemble the front hub to do the wheel bearings and lower ball joint.
On the lower joint, there doesnt seem to be any circlip visible. Is it a press in dealeo? Interference fit?
How does it come out?
Old 02-21-2010, 11:33 AM
thumper64's Avatar
Default Re: EG lower ball joint
There should be a large clip around the joint, flush with the knuckle. It is pressed in and takes a lot of force to press it out. The best way to do it is either take it to a shop or if you have an impact wrench, rent the ball joint press and Honda adapters from Autozone and use the impact to tighten and loosen the tool to press the joints out and in. Doing it with a large wrench is possible, but the impact makes it a breeze.
Old 02-21-2010, 11:58 AM
Funanin's Avatar
yea you can do it with the autozone ball joint press kit, but ONLY if they have the honda adapter kit to rent as well otherwise its pointless and you can either take the whole hub off and take it to a shop with a press or just take the car over and have them do it (which sucks i know).
Old 02-21-2010, 12:19 PM
thumper64's Avatar
I did it without the Honda adapters once. It was a pain, but all I needed was a bike peg and big hammer to get the old joints out the last bit.
Old 02-21-2010, 03:02 PM
mattbatson's Avatar
Ok, so there IS a circlip hidden in there somewhere.
I planned to take it to a machine shop anyways to get the wheel bearings pressed in along with all the old rubber bushings pressed out and new poly ones pressed in.
So, I'll prolly just remove that circlip for the guy beforehand.
thx for all the info
JohnnyEF
02-09-2014 09:31 PM
BCGARAGE_ED7
13
02-11-2013 01:47 AM
Hill4589
10-17-2009 10:06 AM
Powered by VTEC
01-01-2008 10:51 AM
2camsaam
21
10-01-2003 07:32 PM
Quick Reply: EG lower ball joint
