need help deciding what motors and trans is best for the money
Old 02-19-2010, 02:58 PM
smileydub's Avatar
Default need help deciding what motors and trans is best for the money
i have a 94 civic cx and i already have it wired for vtec i have about 1200 dollars so i no that probably means sohc so if somebody could tell me whats the best for power and reliability that would be great
Old 02-19-2010, 02:59 PM
kaiba's Avatar
Default Re: need help deciding what motors and trans is best for the money
What is your goal?
Old 02-19-2010, 03:22 PM
smileydub's Avatar
maybe some bolt ons but overall as much power and reliability for the money more power the better
Old 02-19-2010, 04:05 PM
rycrkt's Avatar
d15b from tiger, jdm sohc vtec. About $700 shipped and you'll have money for a new clutch, timing belt water pump, plugs, wires, oil, coolant, maybe a cheap header and intake. I'll sell you an exhaust later.
Old 02-19-2010, 04:14 PM
FlewByU352's Avatar
IMO save up more, even if you get a B18B motor, its still going to be faster with and without mods. Atleast B series opens the gateway to more mods. Think of if you have the best D series and still have long gears and no power then what? Aftermarket parts are the only option. Atleast with even a lower end B series there are several different upgrades from other stock motors and then there is aftermarket support. Everyone looks at things differently. I see it as more potential.
Old 02-19-2010, 04:36 PM
tlarimer's Avatar
I spent just under $1000 for my LS swap, That included new clutch, timing belt, water pump, axles, tuneup, gaskets, new distributor, wiring harness, fluids, OBD1 PR4 and OBD1 P75, LS throttle cable, misc parts not mentioned.
So with your budget in mind, you can definately go with a b-series swap and will be much happier with the end result.
Old 02-19-2010, 09:22 PM
smileydub's Avatar
do those come with trans and if they do whats the best sight
Old 02-19-2010, 10:53 PM
Adamvanxxx's Avatar
I would check import yards first, a pretty good LS is not hard to come by. But if all else fails check on hmotorsonline.com. Looking local would probably be your best bet.
Old 02-20-2010, 06:59 AM
300whpej's Avatar
you should be able to find a complete ls swap for less than a grand and have some money left over for odds and ends. if your lucky you might find someone with a b16, but you'll more than likely get a ls tranny. check craigslist for integras that look rough as ****, but are driveable, then go test drive and lowball, you'd be surprised at how many integras you can find for a grand or a little more. if you go with a junkyard, the complete swap should cost about 300 leaving you money to rebuild the motor and have a fresh engine for dumb cheap
BrianB16A2
01-22-2014 09:05 AM
d16z6civic811
08-06-2010 11:37 PM
Dizayne
08-03-2010 01:31 PM
ChumBucket
83
12-29-2009 08:47 PM
G2_Fella
10-09-2008 09:32 PM
Quick Reply: need help deciding what motors and trans is best for the money
