HELP:: Bent piece inside OIL PAN. car starting to seem clogged? Picture inside
Re: HELP:: Bent piece inside OIL PAN. car starting to seem clogged? Picture inside
thats ur oil pickup. it takes the oil from pan to rest of motor. def buy a new one if ur having problems a bad one can destroy ur motor of oil starvation
As stated above, I would definilty have one in perfect working.
I know you probably dont, but worth asking. Do you have an oil pressure gauge, what does it read ?
If not, has your oil warning light come on when cranking cold ?
I would replace it for safe measure. as DVDr said, it would be nice if you had an oil psi gauge to see what the pressure is actually reading at. The stock oil psi light only comes on once the psi drops below a certain number. It could be slightly above this and the light not come on. Or that's how I have heard the light is setup anyways.
I put an autometer oil psi gauge in my car years back and wouldn't trade it for anything.
lol yeah i dont have an oil pressure gauge. my oil warning light never came on. it sometimes does for a split second after i get the car started but goes off right away.. any ideas how much these oil pick up cost?? hopefully i still have time to change it out since my motor seems to be dieing
EDIT: I saw your other thread that said you have a d16y7 and i was wrong, they are super cheap online. hondapartsunlimited lists it for like $11.
also it looks like the y7 and y8 share the same pick-up but the older d-seires list a different part# so i cant confirm that they are interchangable
there is a small paper gasket that sandwiches between the oil pump and your pickup. it will require replacement. both the oil pan and the pickup gasket require you clean the metal surfaces thoroughly prior to replacement.
take your time and do it right.
g/l.
g/l.
user 93082343
14
03-30-2009 10:34 PM
