Car wont stay on unless You "HOLD" key in turn on position
Wanted to know if anyone had this problem.
My car wont stay running unless i hold the key in the start position once the car is on. if it bounces back the car will die. the car will start up everytime but once in a while this will happen. Installed a viper 5901 but this issue didnt start until after the swap was done.
i have an Ek with a 00 b18C swap.
checked the wires and nothing that i can see.
Thanks!
Thanks!
Re: Car wont stay on unless You "HOLD" key in turn on position
the ignition switch, is the assembly you insert your key into, its attached to the steering column behind the steering wheel, i believe thats what needs to be replace, that would mean you'd also need a different ke for your new switch
http://techauto.awardspace.com/ignitionswitch.html
Googled it and found that, should be enough info there.
YOU ARE MY HERO!!!
safedriver
05-25-2012 02:48 AM
badfish2282
05-15-2009 08:45 PM
91hob20hb
07-17-2004 11:16 AM
