B16 Yonaka mounts
Re: B16 Yonaka mounts
How far off are you? Mine worked great, and are still holding up strong. I actually like them for the price. Sometimes a bent bracket can do this, or also tightening one or the other up too soon can mis-align the rest. Try to get them all lined up then tighten them down.
there are two differnt b/dseries drivers mounts, there is a 2-hole mount and a three hole mount, I believe the 3 hole mount was used from 94 up
You have the wrong mount on the engine side. You need to remove the top timing cover and replace the mount bracket from the motor. I just sold one too. Gl man.
Seems like you got the answer, Best bet is find an integra from a junkyard. and buy the piece ( mind you its a pain to take off while the motor is in the car, so maybe a freind has the piece kicking around.
alot of EK owners that swap b18bs have them kicking around.
yo i was wondering on the yonaka motor mounts.
are they Solid with No holes to put inserts inside like oem motor mounts ?
or is the holes filled in with polyurethane bushings foams
like after market Avid, innoative mounts.
Get a new Yonaka mount. OEM mounts with Urethane filling aren't as stiff. I ran my car with a urethane passenger mount, an OEM driver's mount filled with urethane, then switched to a solid Hasport urethane driver's mount and noticed a little more vibration but better hook up. Anyone who says Window Weld is an equal alternative is wrong, including me 6 months ago.
I just got a set of yonaka mounts. The motor mount for the driver side im having issues with. The holes to mount to the motor bracket are way to big for the studs.
Fish Twig
Since you're not asking for help on how to solve this I vote this thread closed.
Originally Posted by TomCat39
If you don't post it falls to the bottom of the heap, which is was on it's way when you read and then decided to hit reply.
Last edited by TomCat39; 08-17-2014 at 08:15 AM. Reason: Letting it fall to the bottom of the heap.
