suspension question?
will a set of 99 civic suspension fit on a 95 coupe???
ps i have ek lower control arms wanting to trade for eg lowercontrol arms
Re: suspension question?
Why the hell are continually posting that useless crap?
OP - ek suspension will fit on an eg. If the shocks are off of an ek you can use either set of lower control arms. If the shocks are off an eg then you will need the use the rear lower control arms off an eg.
I've got eg front shocks/springs on my ek up front and found the rears did not mount up due to the mounting tabs being to short not allowing full range of motion needed in the rear.
so ek lower control arms wont fit but will the eg lower control arms fit? or will it mess up the lcas when u grid it down
yes ek lcas will not work in a eg.
yes you will have to grind down the bushing on eg lcas to fit a ek shock,
egs are just a little wider then ek shocks are, its been done tons of time before. your not actullaly grinding the lca down just the bushing.
BrianFreels
05-04-2009 01:36 PM
jaybird8805
04-01-2009 03:47 PM
