My car wont do nothing....NOTHING
I just recently put my b16 into my hatch and for some reason it wont do anything. it doesn't turn over, the fuel pump doesn't come on, nothing is happening, i turn the key and nothing. help me please. and suggestions on wat i should check.
Re: My car wont do nothing....NOTHING
maybe you have a faulty ecu? or you connected the engine wiring harness wrong. Did you make sure you did it right?
I knw its not the ecu because it was perfect in the pervious car, but maybe the engine wiring harness is wrong, i will check that, and the main relay, and ignition switch.
yea its not the ecu, the car will still crank even with no ecu connected. Try the main relays on ignition and fuel pump, or fuses... do you get any dash lights on when u turn the key or no?
slow hatch
04-19-2004 10:00 AM
Red_Si
13
05-07-2003 03:21 AM
