EF SiR Brakes on EG
EF SiR Brakes on EG
Hey, I own a Honda Civic EG8 which has rear drum brakes I can pick up some cheap rear EF SiR discs, calipers, & pads. Will they fit instead of the drums if I use EG/EK/DA trailing arms & hand brake cable?
Any help would be greatly appreiated.
thanks.
thanks.
New User
Re: EF SiR Brakes on EG (VTCPWR)
the trailing arm and brake line placement will be slightly different. what i would do if u wanna use them is remove the drum brake hub (4 star shaped bolts, be careful they strip really easy) and do the same with the EF disc brakes and swap them over. u will have to get creative with the brake line mounting points tho. but it will work including the e-brake cable
02-04-2013 11:55 AM
loudsubz
07-13-2004 05:52 PM
