5G Hatch and suspension/GSR brake question
I have a stock 93 CX I plan on hybridizing (surprise..) just for fun an autocrossing. I'm going to upgrade the suspension first, and I'm thinking about my first investment being a bushing kit, Eibach sportlines, and Koni yellows.
This spring I plan on buying a GSR as a doaner car, for both engine and brakes (and hopefully a tac.. hmm precious tac). When I swap the lower control arms for the GSR parts so I can mount the rear disks, will I need different rear shocks? I've had some searches show up saying both cars share the chassis, so I can swap the suspension parts *****-nilly. Others suggest differences.
Thanks in advance.
PM
Thanks in advance.
PM
Re: 5G Hatch and suspension/GSR brake question (project_mercy)
yes you can swap the whole suspension from the TEG, in the front grab the sway bar, LCA, knuckle with rotor and caliper,
rear grab the whole thing, which includes LCAs, sway bar, complete trailing arm with brake lines and e-cables.
shocks can be used as well..only thing is that it will give you a 4x4 look with the oem springs
Re: 5G Hatch and suspension/GSR brake question (eg6ajk)
Thanks a lot for the info, my question was more this though:
I'm buying a set of springs & struts flagged "for '92-95 civic". But when I swap out the LCA for the 'teg ones, I assume they'll bolt up to the civic springs & struts, but will it stay at the same ride height/suspension. Aka, will it look like it has droopy drawers, or jacked-up camero action.
if you are going teg suspension bits, then buy teg shocks/springs
i would save up more money and get some zeal b-2 coil overs. the koni/eibach setup is okay, not really worth it. when you can spend a lil more and get a true coil over
Re: 5G Hatch and suspension/GSR brake question (Bob-DC2)
No offense Bob, but why would you need 'true-coil overs' if your just going to be on the street and auto-xing? I think that most drivers wont be able to over drive some nice springs and struts, but wouldnt come close to using the full potental of nice coilovers.
TTT for al.
-Jake
TTT for al.
-Jake
Re: 5G Hatch and suspension/GSR brake question (SuperHatch)
Mugen "true coilovers" 1000$ (Kingmotorsports.com) plus shipping 20 bucks ..
300 dollar diffrence for mugen coil-overs ..when I get the money I know what I would get .... Just my opoinion
[Modified by owen_the_soyboy, 11:35 PM 12/16/2002]
Re: 5G Hatch and suspension/GSR brake question (owen_the_soyboy)
yes you can use your spring/shocks from the civic as long as it's not an itr youre getting the lcas from
floridaEg8ferio
11
03-29-2011 06:26 PM
ImportRicer
01-30-2005 09:52 PM
Skeletor
03-17-2003 07:55 PM
tnbigdawg
02-02-2003 06:24 PM
hybridcivic93cx
04-22-2002 12:44 PM
