help w/jdm cluster
help w/jdm cluster
sorry guys but i am a noob...i did a search on it but couldn't find any answer's to it...i just installed my eg6 cluster and it doesn't light up all the way...i've searched on it and it says that it has no dimmer switch...well it doesn't really light up and i want it to light up(really dim i think its set at it's lowest setting)... is there any other way to make it a little brigther..let me know what you guys think..thanks...
Re: help w/jdm cluster (blacksheep5q)
JDM don't have the dimmer adjustment, you can change the bulbs to some newones off your old cluster and hope it helps also clean it up with some alcohol, tighten the grounding screws a little..
otherwise you SOL
otherwise you SOL
**** out of luck maybee?? as for the gauge cluster just take the bulbs out and put them in your old one and sell that thing...here in america we use MPH.
Re: help w/jdm cluster (95excoupe)
Mine had burnt out bulbs, I replaced them and its bright now. There is also a way to splice the dimmer switch into the wiring but I haven't figured it out yet.
itsJDMyo
14
10-19-2003 05:22 PM
