Need some info
Need some info
1rst off I got a B18C1 in a 96 coupe
Looking through the Haynes manual and I just found out why I cant get Cruise control due to variations in the electric Controller and the vacume controller. So what do I need to get to have the CC work? 1rst problem
Also the A/C what bracket do I need to mount the pump back? i know its from a Del sol but what part? 2nd problem
Also I need a steering column. What can I get? a GSR column? or do i have to get a Civic colum? Since I am going to run the Integra CC if I can. So I need to have that steering colum or do I need the Civics?
TIA
[Modified by B18C1 '96 Coupe, 11:38 AM 12/15/2002]
TIA
Re: Need some info (B18C1 '96 Coupe)
i believe the ac bracket you get is the ac braket from a delsol vtec(B16a) and im sure you get a civic column.
i canthelp withteh CC problem
Re: Need some info (Soulless)
either a del sol vtec bracket or one off the 99-00 Si civics will work. you can order them new from http://www.hondaautomotiveparts.com. don't expect to find any in a junkyard its near impossible. new they run a whopping $100 each! why do you need to change your steering colom?
Re: Need some info (snail)
who cares about CC?
im about to take mine out and sell it, and use the button space for my fogs.
it will shave you a few pounds, and free up some space along the right side of your bay.
Re: Need some info (Paranoid Android)
Someone broke into the car and broke the ignition holder and got in. Plus security of a new key other than what the VIN may pull. But as I looked at it all it seemed to be broken on the colum. The CC thing I commute to work. SO its kinda nice to not have to keep Acc and Decel. If its not possible its cool. But I would like it.
hondaboy4life
08-14-2006 07:32 PM
DelsolioGSR1996
08-03-2006 06:41 PM
CTL
19
05-05-2004 01:57 PM
