A LS rear sway into a civic????????
What is needed to make it fit I know you need the "d" brackets what about the end links they are not the same ones as the ITR or the SI.
Re: A LS rear sway into a civic???????? (b16b hatch)
sorry not too much help here but i thought the ls and the gsr have the same rear sways? and depending on how the bar is attached to the lca you could always just go to kragens or whereever and pick up a set of endlinks that might work. and dont forget bushings. but like i said shops do sell brackets bushings and endlinks, for like $20 or so i believe
don't forget the type of endlinks differs on what LCA's setup you are running.. as I do believe 92-95 civics.. will need to use Integra endlinks.. while 96-00 civics will be using SI endlinks in the rear for the swaybar
Re: A LS rear sway into a civic???????? (intezn)
This is a picture of an endlink connected to a SRR LCA...
YES I DID JACK tonyxcom pics =P
[Modified by IM ALL BOB, 10:57 PM 12/16/2002]
cafrog
36
06-18-2009 02:37 PM
Prudz_lude
01-17-2008 03:57 PM
Two_K Si
08-21-2003 06:26 PM
